sijoko »
https://forums.nicoclub.com/sijoko-u297.html
Mon May 31, 2004 1:16 pm
I replaced the subframe bushings on my 94 Q with Energy Suspension Polyurethane subframe bushings for a Z32 300zx.
They fit with slight modification. There will be some more harshness coming from the rear, but to me it was not a big deal.
The only issue is the amount of time and effort it takes to remove the old bushings. You pretty much have to burn out the rubber part of the bushings and then remove the metal sleeves with a hammer and chisel.
Once you do that, everything is pretty easy. Just press the new polyurethane bushings in by using a rubber mallet and some grease.
If you are mechanically inclined, then I would say go for it. But if you are having a shop do the work, then just pay up for the new subframe.
I didn't want any more issues with a leaking subframe bushing, so I went with the polyurethane ones. I have put about 10k miles since I replaced them. So far, no complaints.
-sijoko
