dousan_pg »
https://forums.nicoclub.com/dousan-pg-u38955.html
Sat Apr 08, 2006 5:38 pm
my friends car broke axles w/ the solid subframebut his car makes 350 HP full track car for drifting, so fo most i wouldnt do it
for me i wont either, track car and 350 in about..mm 2-4 months after i pull and rebuild the motor. everything else is solid, i have no wheel hop. use solid motor mounts (but that doesnt affect wheel hop) and subframe spacers on a s14 subframe (for s14 car). my s13 had just the stock subframe, but it wasn a s15 onsubframe on the s13.
anyways..do as you wish but its not worth the work.
as far as ujoints on the diff, on the s13 there ARE no ujoints, its solidly mounted to the subframe, unless your on a s14 where the front two bolts are bushing mounted.
as far as wear on the transmission NO because the transmission wont be affected by bushings. what are you talking about??? maybe ur transmission would get affected if u didnt have fluid in there.
as far as handling i ran stock s13 subframe all suspension arms, good coilvoers and there's no 'swoopy feel' my friends the same way. set up a car wel and its solid w/o dropping subfrrames. get adj aftermarket arms and some rear sway bar and its solid if not TOO solid and twitchy.
btw ive talked w/ kuah (Splparts.com), he said it wasnt even worth it, btw im sponsored by SPLParts.com...you can check if u dont believe me, SPLParts.com talk w/ kuah, my name is aaron, PINK GODZIRA, ive been w/ kuah and hooked up by splparts for over 3 years, i LOVE splparts.all my suspensio is from them and so is myfriends (aaron and lindsay we both are good friends with kuah). all my Defi BF gauges (and link) all suspension arms, and tons of misc stuff i buy from kuah. ive been waiting for the new seat (bucket) to come out because i need a bucket passenger for the track car. lindasy's car was theone of the test cars for the z32 setup before he released it. iirc we tried some other stuff on our cars before he sold them to the public. kuahs been helping us out for about 3 years now. he's a great guy, and came to cali a few times for z meets and driving stuff...nice guy. with a wicked awesome car! and veryknowledgable, but im getting off topic now..anyawys...
personally i would recommend away from it, get aftermarket arms, subfrme apscers and somegood coilovers. its worth it. less headache easy install and u dont need to drop the subframe (as long as you get the top split type). a good alignment good coilovers and tire setup is enough to keep your car solid, and feeling great. its worked for me for bout 3 years+ on both my s13 and s14 and my friends' cars.
