Rear subframe bushes
Shogun
Car: Nissan 200sx (240sx), S13 with a CA18DET with +700hp
Anyone who can tell me how to change the bushes or how to improve?
R240NA
Drop subframe, burn old ones out, press new ones in, reinstall subframe. Done. Questions?
flip240
If you are talking about the rear subframe bushings, they don't need to be burned out, b/c there aren't any. There is 4 metal bushings that you can get to place into the subframe supports. The reason they aren't there is b/c they transfer alot of the subframe noise that you wouldn't normally hear into the cabin. But if you do heavy drag and cornering, they are highly recommended. There is a guy who makes them in his shop at zilvia, or you can check them out on the zilvia group buys, or pdm racing sells them too.
R240NA
flip240 wrote:If you are talking about the rear subframe bushings, they don't need to be burned out, b/c there aren't any. There is 4 metal bushings that you can get to place into the subframe supports.
So, the subframe is just floating in air? Cool. Don't reply when you don't know the answer. There ARE bushings, otherwise there wouldn't be a need to replace them. They are like FWD motor mounts, only a portion of the center section is actually rubber. The collars, or spacers, you mention fill in the gaps above and below the subframe mounting points, but they do transmit more resonance and noise into the car. Nismo makes rigid repalcement bushings that are less harsh and more forgiving.
