Rear Strut Problem....
MadmikeX3
Car: 1990 240sx SRBLKTOP With a potatoe
Okay today I installed a Set of KYB GR2's on all four corners. But the rear do not work right. I tightened the mount all the way down on the Spring(Eibach Sport lines) Now when I installed the rears and set the car down and went to drive they where rattling around. when i got out and reached though the trunk to feel them there was a small gap under the nut and the washer was loose as well. So i took them off to tighten more and i could not. I even snapped off the Small tip above the nut you use to hold it form spinning on one. They are tight Really Tight. But still the Same Problem. I missed nothing and transfered all hardware form the stock ones over. Any Ideas?
94_240sx
Car: 94_240SX
Maybe top of the strut is touching infamous rear bracket/reinforcement metal thingy? You might have to cut and bend it. That's what us coilover people do.
