Rear strut knuckle bushing
wideopn11
Car: 2012 Infiniti M37x Moonlight White
Takeda CAI
Stillen exhaust w/ MeganRacing Y-pipe
SCALE coilovers 16K/10K F/R
Akebono BBK
Cusco strutbar
25mm spacers F/R
Uprev tune by seymore4
Has anyone had to replace this part? It's a ~$15 part#562195CA0A. If so how much was the labor, do you need a machine press, would I be able to to do it myself? Is there a better upgrade option for the bushing? Thanks for the help.
Debonair
Car: 2011 Infiniti M56
Never done it but based on my experience with similar parts I would say a press is almost certainly needed. Your lowering spring thread has a good picture of it. Labor should be minimal to have it done if you carry the axle housing (knuckle) into a shop. Drive up labor will be more of course. Can you do it? Sure with a press and the right size tool/socket/pipe to press it out with. I bought a 20 ton press years ago with has payed for itself many times over with small jobs like this. Pro tip: freeze the bushings overnight to assist them with slipping in easier. There are upgrade options for the 350/370Z cars that may fit. You will probably need to take measurements to see if they will work.
OR you can remove it like the guy in the video below which is on the car and seems easy.
wideopn11
Takeda CAI
Akebono BBK
Cusco strutbar
25mm spacers F/R
Thanks Debonair! That's a great video you found and I'll bet those 370z bushings are the exact same size as the M37.
https://www.enjukuracing.com/products/s ... 3-z34.html
370z on the left - M37 on the right.
Malbec 56 Beast
Car: 2013 Infiniti M66xS Totaled 4/11/20
What's next???
2010 Subaru Legacy
1983 Porsche 928 S Euro (Sold) 2/17/20
Do those require removal and replacement when doing coilovers?
Andy
Debonair
Malbec 56 Beast wrote:
Mon Aug 21, 2017 3:32 pm
Andy
Nope. I'm sure Wideopn11 will let us know but my guess is that he has excessive play and/or noise coming from his prompting him to change them.
wideopn11
Takeda CAI
Akebono BBK
Cusco strutbar
25mm spacers F/R
Actually I have to replace the right side with OEM or upgraded bushings because the rubber has deteriorated and the bolt is rusted/seized to the sleeve of the bushing. :mad: :tisk: :facepalm:
The bushings do not normally need to be touched when replacing OEM with coilovers but because my right side is ruined I don't have a choice.
Malbec 56 Beast
What's next???
2010 Subaru Legacy
Oh ok, makes sense.
Are there any bolts that aren't included in the kit that I need, I thought I read that one of the bolts is welded to the stock shocks and not included in the kit.
Thanks
Andy
Debonair
Ahhh...rust. I always forget environmental related issues. Cali brain. :facepalm: :chuckle:
wideopn11
Takeda CAI
Akebono BBK
Cusco strutbar
25mm spacers F/R
Mon Aug 21, 2017 5:35 pm
Oh ok, makes sense.
Thanks
Andy
My SCALE kit came with everything; bolts and nuts for the rear (OEM has welded nut on the strut), Extenders for the rear adjustment since the back seat has to be removed to access.
Malbec 56 Beast
What's next???
2010 Subaru Legacy
Wide,
My kit is the same (BC/SWIFT) as yours minus the nuts and bolts.
Are there any part numbers or size/dimensions for the nuts and bolts in the kit. I want to be prepared when I go to get the suspension put in.
Thanks
wideopn11
Takeda CAI
Akebono BBK
Cusco strutbar
25mm spacers F/R
You can reuse the OEM bolt and the BC kit also comes with the nut. I can measure this weekend and see if the info is labeled on the bolt and nut size needed.
wideopn11
Takeda CAI
Akebono BBK
Cusco strutbar
25mm spacers F/R
So umm, yeah...after 3 hours of fighting with this seized bolt and bushing...I win!
wideopn11
Takeda CAI
Akebono BBK
Cusco strutbar
25mm spacers F/R
And also the video above method for removing the bushing and pressing the new one in worked like a charm. I was literally stupid easy to press that bushing out and install the new one with the right tools. After cutting the old bolt out first of course...
Debonair
Awesome!
Malbec 56 Beast
What's next???
2010 Subaru Legacy
Wide,
The reason you had so much difficulty is that there wasn't nearly enough open beer bottles!
You let us down, I don't know if I can forgive you for that.
Beginner!
Lol great work man.
wideopn11
Takeda CAI
Akebono BBK
Cusco strutbar
25mm spacers F/R
Mon Aug 28, 2017 3:59 pm
Wide,
Beginner!
Lol great work man.
:rotfl Oh there were plenty good sir :lolling:
