goody90q45 »
https://forums.nicoclub.com/goody90q45-u31761.html
Tue Jan 31, 2006 6:00 pm
I got a 20mm rear stabilizer bar from a 93 Q45a abandoned at work and will be installing it this weekend on my 94Q. It was a simple removal and will be an easy installation. I've purchased the rubber bushings and three are the same (54612-01P00) but the 4th (54612-35F00) has a short neck on it.
Question #1- Looking at the picture below from the FSM, what is the correct location for the bushing with the neck? From the posts I've read it looks like it may be the one closest to the ground when mounted on the connecting rod which means it would be attached to the sway bar.
Question #2- I haven't looked under my Q, but I am assuming (hoping) that the holes for the connecting rods and threaded holes for the clamps are predrilled into my suspension components even though the std. Q does not have a stabilizer bar. Is this the case?
Thanks in advance for your responses. I am looking forward to the improved handling the stabilizer bar offers and will post this weekend on the results.
