alexf20c »
https://forums.nicoclub.com/alexf20c-u34818.html
Tue Feb 02, 2010 4:25 am
you have to remove the coils to install the bags, but it's still an easy install. drill out the hole in the coil base so you can fit the air line through it.
the nipple should face down and i'd recommend running individual air lines from each bag. this is going to be a permanent thing because the audio equipment is permanent, so there's no point in running them to a tee.
also, by running them separate, you can adjust from left to right, in case the load is not perfectly balanced and you have a little bit of a lean.
