Rear springs
VG33QX4
Car: 2000 Infiniti QX4
i need to replace mine they wore out i beleive as i bottom out hardcore with a passenger in the back. my bump stops are gone but i shouldnt be hitting them with a single passenger.
with the money i am willing to spend i have two options. replace 10 year old 150,000 mile springs with new ones or get bump stops replaced. looks like same money
where can i buy oem or oem equivalent springs for 2000 q thanks
Chuck Tribolet
Car: '01 Nissan Pathfinder
'87 Chevy Corvette
'01 Toyota Camry daily driver
'98 Boston Whaler Montauk
If the bump stops are gone, you need to replace them. It's easier, and I suspect, cheaper, than springs.
And if the truck isn't sagging the back at rest, you don't need to replace the springs. Springs don't get soft with age, they compress.
Chuck
VG33QX4
Bump stops are 80 bucks. If it still bottoms out cause the springs are weak no point. I am worried of the longevity of the airbag install and just figured replacements springs would have the least point of failure
Chuck Tribolet
'87 Chevy Corvette
Again, if it's not sagging at rest, there's no point in replacing the springs. And you haven't complained that it was sagging at rest.
Chuck
ARKQX33V6
The springs should be measured unloaded, but that requires taking them out, so measuring your height as per the book will give you numbers, meet them, then your OK. The QX4 has weak springs in the back and a single person can make the car bottom out...the only complaint about the car
CanuckQx4
Car: 2001.5 Infiniti QX4 2WD
How big are the springs supposed to be??
VG33QX4
just ordered the air lift 1000 20 dollars more for them vs replacing the bump stops.
CanuckQx4
the bags in my airlift kit cracked and split open after the first winter on my car, not built for canada..
VG33QX4
great. and that was my worry.
although it only gets hot where i live, coldest it will get might be 33 in the south
anybody else had these things not last long? either way they have a lifetime warranty on them FYI.
CanuckQx4
Its not the warranty I really cared about, the fact that you have to pull them out , send them off, then get new ones and pull everything out again to install is what sucks
I probably wont even bother with sending them back, was never happy with there poor performance
