Rear Spoiler Clips
Tydirium
Car: 1991 Nissan 300ZX Z32 TT
2019 Nissan Rogue SV
Good day. I have a 1991 300ZX Z32 TT, one of the plastic rear spoiler clips has failed thus the driver side spoiler edge has lifted off of the back hatch. I am having problems finding replacement clips. Z1's website shows they have been discontinued, I plan on calling them tomorrow to check on equivalents.
Requesting some help please regarding if anyone has had success with other sizes or types of clips? My next resort is using a bolt, washer, nut etc which will require some disassembly of the back hatch. Thanks for the help.
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
Nissan 96070-42P99 Clip
Is this the part you're looking for?
I tried eBay but had no luck turning it up. I couldn't even find a cross reference for other vehicles it may have been used in.
Supposedly NissanPartsDeal might have a few on hand. They sell them as a pack of 10 for $5.44 But I'd give them a call (1-888-726-6993) to verify availability before trying to place an order.
Tydirium
Thanks very much Rogue One for the help & assistance. Likewise: I could not find any and Z1 also had no cross-referenced clips either.
I wound up disassembling inside the hatch. Used a stainless steel, round headed bolt on each spoiler end + washer, lockwasher and nut. Prior to torquing down the nut I ran a bead of 3M 550FC polyurethane on the inside surface of the spoiler. Took a couple hours, a few bad words were said, but happy with the job.
Rogue One
2022 Honda Pilot SE
Glad to hear everything worked out okay in the end. :bigthumb:
Thanks for the detailed write up on how you were able to fix it. Even though you didn't find the clips, someone may find your solution helpful if they're in a similar situation.
