Liquidus »
https://forums.nicoclub.com/liquidus-u11556.html
Tue May 31, 2005 10:56 am
Okay, here's some more info that will hopefully help you help me.
I did some testing today using both my 240's one has the problem, the other is fine, and here is what it up.
It's not the cd player unit itself.It's not the speakers.
It has something to do with the connection between the cd player and the rear speakers. I borrowed one of those ohmmeters, or whatever they're called (sorry, don't know alot about electical stuff). I did some testing and found a problem.
There is no connection between the rear speaker connector for the cd player, and the rear speaker connector for the speaker. The thing is there isn't anywehe that i can see where the connection is broken. On the left rear the wires had been cut and twisted back together. I checked them out and put one of those crimping connectors on it.
Still no connection between both the positive and negative connectors for both speakers.
Is there a fuse somewhere that i can check? Please help!
Thanks
