thats one of the speaker sizes I had seen on posts, but I took out my trunk interior and went to a sound shop
we test fit everything he had from 4 to 5.25
4 is way too small, and 5.25 will fit on top of the enclosure above the lip set for the factory speakers but looks like they would fit if I cut some of the enclosure but its plastic... if I put the interior piece back on it presses down on the speaker somewhat and no speaker operates properly like that
they are powerred speakers, they have a port and an amp for each
ill check out some classifieds to see if theres any brackets I could use
EDIT:
looking at sonicelectronix.com it shows this for all BOSE 90+ 300zx
Front: 4"
Rear: 6-3/4"
Front door: 4"
Rear deck: 6-3/4"
and shows this for all 84+ 300zx without BOSE
Front: 6-3/4"
Rear: 6-3/4"
Front door: 6-3/4"
Rear deck: 6-3/4"
I found on Z1 they have 6.5inch enclosures that dont come with the amp or speakers (also 4.5inch and 4x6), would the amps in my 5inch enclosures work for 6.5? im guessing it wouldnt be an issue? pull em out and put em in the other enclosure?
