EW »
https://forums.nicoclub.com/ew-u28959.html
Sat Jul 19, 2008 7:02 am
You will probably need to remove the rear deck trim panel to remove the plastic grille. The grille covers are usually attached with screws from the bottom side of the deck cover. Each car will vary. Many times, the rear deck is rattling against the bottom of the window or against the metal at the bottom of the window.
