Rear shade motor
doc7592
Car: 1999 Q45T
Help needed my rear shade has stopped working. How can I fix it? 99 Q45tAny part#'s Please point me in right direction
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Hello and welcome to the NICO forum
Heres the part number for the sunshade assy.....
97580-3H100-
However, in the list for the motor and gear, it lists REFER TO TSB
and it gives this part number for the sunshade: 97581-3H000-
What I would do is call Joe up, and tell him you have a 1999 Q45 and tell him you want the rear sunshade motor... Tell him your from NICO and you know Wes and all that fun stuff... When your on the phone with him, tell him to go to section 799 (he'll know what I'm talking about) and scroll to the very end.....
the rear sunshade is the last diagram in section 799.....
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Be sure it is not jammed first.
The price of the shade assembly is not inexpensive.
doc7592
Car: 1999 Q45T
how do I checke to see if it is getting power.
xmateo
Car: 04 G35 Sedan
I'm having the same problem with my '99 Q. How did you fix yours? Was it the motor?
xmateo
Car: 04 G35 Sedan
How do you tell if it is jammed or not? Is there a possibility it is catching on something that is not allowing it to extend?
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
xmateo wrote:How do you tell if it is jammed or not? Is there a possibility it is catching on something that is not allowing it to extend?
Check the extension scissors. They can get bent.
xmateo
Car: 04 G35 Sedan
I'm a little afraid to pull on it - it seems to be firmly in there. Am I going to do any damage to the motor if I force the top of the shade out?
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Remove the whole unit to check the operation of it.
xmateo
Car: 04 G35 Sedan
maxnix wrote:Remove the whole unit to check the operation of it.
Suggestions for removal? I don't have the slightest idea where to start.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Look at BT-29 and BT-31 in the FSM.
