The00Dustin »
https://forums.nicoclub.com/the00dustin-u137235.html
Tue May 06, 2014 2:57 am
I may have posted a similar thread like this once upon a time. However, it wouldn't have been called rear sunshade and lockout switches. My posts also may have been in a nav hack post, or I may have never made them and only dreamed about it. Regardless, I have the premium package without RWD (which is what you have pictured). The rear sunscreen switch is definitely momentary, you can release it and the sunscreen goes all the way regardless. The rear control cancel switch is definitely mechanical, it rocks and stays that way when you push cancel (when sitting as pictured in your post, it is in the on position). However, I doubt it is multi-pole. My idea was to use the blank and fabricate a double-pole double-throw push button into the blank cover. This would require significant fabrication, but be really cool because it's blank and no one else knows it's a button. I'm not much of a fabricator, so I never messed with it, but I had found a double-pole double-throw (mechanically) latching push button that would easily fit under it that cover and probably be easy to fabricate into it (if anything it would be too small). You might go searching for that thread, but since I'm not sure it exists, that could turn out to be quite the snipe hunt, and the only thing it would provide would be the link to the button (which may have been posted by me) or the site with the buttons (which may have been posted by someone trying to help me). Nonetheless, I wanted to answer your questions and stick a cool idea in your head (regarding the blank cover).
