rear sensor
John82654
Car: G 37 sedan
A person hit my rear bumper and knocked the sensor into the bumper I guess. Now the sensor makes the sound t makes when you're too close. Is there any way I can get into the bumper and put the sensor back in place? Sorry a G37 x sedan. Thanks in advance!
13_SkylineSedan
Car: 2x 2013 G37 sedan 2WD-7AT (his and hers)
Sad! And irritating when in reverse. Sorry to say the sensors are mounted from the outside and snap into place. So you need to get behind the bumper, unplug the sensor that has been pushed through, feed the wire through the hole, reconnect the sensor and snap it back into place from the outside. Also be aware there is a specific orientation for each sensor - has to be facing the correct way and can't be spun or it won't "see" properly.
Go here:
http://www.nicoclub.com/archives/infini ... nuals.html
find your car and grab a few service manuals. "sn.pdf" is the sonar system. You might also want "ext.pdf" in case you need to remove the bumper.
