MobilS13 »
https://forums.nicoclub.com/mobils13-u41458.html
Fri Sep 29, 2006 9:20 am
I have been trying to fix this problem for about a week now, I have searched many times and tried all the solutions people have suggested, but no luck. This is a 93 base coupe.
When I bought the car the p/s headlight, the gauge lights and dome light were not working, I am not sure about the running lights because I never drove the car at night. I had an aftermarket stereo put in and noticed that they left a ground wire loose. I grounded that out then replaced the headlight switch and that fixed the headlight.
I have also replaced the dimmer switch and TCU, all the fuses are fine and I checked the wires from the rear lights but can not see anything wrong with them.
I see that the running lights and brake lights are wired together in the rear bulb assembley. I don't know if this is supposed to be that way. But I pulled the bulb assembly and checked the the connector from the chassis with a volt meter and noticed that when I push the brake there is a signal, but when I let go of the brake there is no signal.
I read something about the fusible link under the hood, but I am not sure what I am supposed to be checking for there. All those fuses (I am not sure what they are called) are fine as well.
