240sxdominos »
https://forums.nicoclub.com/240sxdominos-u22876.html
Tue Jun 19, 2007 11:25 am
Ok I have searched and what I found for the rear rotor removal was that the rotor is just supposed to come off with some force. I also have the Chiltons guide for the 240sx and it says for the "wagon" which I can only assume means fastback (which I have, a 1990) requires removal of several pieces including the grease cap, cotter pin and adjusting bolt before you can remove the rotor. So for my question, which one is it? Do I have to remove the other parts before taking off the rotor or should I just hammer the thing until it comes off? Ive seen pictures where there are holes on the hub for removing the rotor but mine dont have them. Thanks in advance for the help. -John
