***Rear Quarter Window needs to be replaced. Already searched. HELP ASAP***
mouse
Car: CARS CARS
I bought replacement glass for my hatchback, its the right rear quarter, and its off a parts car, I don't know how to remove the glass without breaking it, someone must have done this before. I really need help. ASAP. Thanks in advance.
pmkls2
Car: 1990 240SX Fastback
Well, because of the contour of the window wrapping around I'm not sure if you're going to have much luck getting the glass outta there in 1 piece. Just be gentle with it and find a windshield removal tool, I think they're only about $20 if I remember correctly. If you cant fint the tool then use a piece of small cable like piano string and run it through from the outside of the glass in (you may need to drill a small hole) and then just work it around the glass and gently pry it out. Good luck.............
180fan
Car: 89 fastback
use the piano string or pay a professional to do it. A local shop charges 70 bucks for a window removal and installation of a new window in my neck of the woods. That's with them coming out to the car. Call around some body shops and glass installers.
pmkls2
yeah, I agree, I'm a mechanic and I'd still pay somebody else to do it unless I was in a real bind ( which is pretty much all the time lol )
