top_secret »
https://forums.nicoclub.com/top-secret-u35327.html
Tue Jan 24, 2006 7:24 pm
wellll... see its complicated. technically, a vert is a coupe that got hacked and welded. SO, somewhere under the vert's structure is a coupe. so theoretically if you are careful with your cutting and welding a coupe one should work. BUT... the way normal body ships repair 1/4's on the 240 is usually to cut along the wheel well in the interior and basically weld on a new corner of the car along the frame rail. So if they just did that then the coupe one wouldn't fit. You'd have to get a very loving and caring body shop to take their time.
