j-z »
https://forums.nicoclub.com/j-z-u11653.html
Tue May 11, 2004 3:12 pm
depending on how severe, all options are already said. if its rusted through pretty bad, you can just cut out the rusted area and weld a piece of sheet metal in. if its not rusted all the way through you can most likely grind it all off and treat the bare metal surface. but, to remove a quarter panel, theres about 150 spot welds that will have to be either drilled out or grinded down. the quarter panel attaches to the rear body panel, the wheel well, rocker, b pillar, and the roof. if youre going for cheap just cut out the rusted area and weld in a new piece. just because its cheap doesnt mean its not a proper repair becuase it is.
