I've always wanted to get a Premium in my search for a 2007 M35x. But they were very hard to find. So I've ventured out in creating my own Premium. I'm working on the Headrest Video, and I'll share in a few weeks of my progress. In the meantime, I got an aftermarket power sunshade and wanted to share the install.
Here are the pieces that came with it:
1) The sunshade2) A wireless RF remote3) Wires and connector to tap into continuous power from the car and ground4) A clip to easily clip a power line from the car (I used the rear trunk lamp), and a ring to hook around a nut/bolt for ground (I used the nut/bolt for the Amp in the rear-left of the trunk).5) An RF receiver/power box that connects to the power and to the shade.
It took me a while just set things up. I had to remove the rear trunk finisher (the service manuals are very easy to follow) to find a power line and place to ground. I thought of using the Satellite radio or Bose Amp, but decided later it was easier and less intrusive to just go against the trunk lamp power (it's the brown wire). I also decided to use the Bose Amp bolt as the ground as it was good locationally.
Here's the hookup in the trunk:
Ground:
Power:
How I went into the trunk (there's a 2.5 x 2.5 inch opening that I could run a wire through right underneath one of the car seat anchor and I pulled the wire into the car from there):
One more pic of the hookup:
I then had to center the shade and test it. It has an adjustment dial for how far up the shade needs to go and after finding the best location and the height/angle I needed. I fixed the two plastic bases to the trunk finisher with 4 screws and voila! I was done.
Here are pics of the shade in different stages of up and down. I'll try to load some videos on the YouTube and share it later. The wireless remote has 3 buttons, up, down, power (stop).
Enjoy!
(Please disgregard the messy garage!!)
Here's the video of it going up:
http://www.youtube.com/watch?v=-APiP0JKpmA
This is of it going down and the description of its operation:
http://www.youtube.com/watch?v=HFWFbO6ojwI
Modified by pangpang77 at 9:33 AM 10/18/2009
