It's too early to be drinkin! S'okay.kmil123 wrote:Whoops!!! another mistake "EverViscious" is actually EVER VICTORIOUS.......once again.....mea culpa! Sorry bout dat.
Not quite. Mirrors don't help when you're backing out of a spot in a parking lot. You need to see down the row to make sure you're not backing out right in front of somebody, but the rear pillar is right where you want to look.Ever Victorious wrote:I have never found visibility to be a problem in the Versa. The rear mirror is sized so that it shows the whole width of the viewable rear window, no more (a larger mirror would be pointless).
My side mirrors are adjusted so that the inner 1/8" of each mirror shows the paint of my car. This brings the view of the lane behind so far inward that I actually have slight overlaps between each side mirror and the rearview mirror (a car behind me I can see in my rearview and at least one side mirror). This eliminates the blind spots caused by the rear pillars.
OK... I'll let them know... that SHOULD be the correct way to do it.kmil123 wrote:I should have been hitting "edit" on MY own post........and as you said, not the one on the top.
blind spot is just that,..a blind spot. Your mirrors won't even help. You turn around to see the blind spot area in most vehicles but in these new hatchbacks even when you turn around you still have a blind spot. I drive a full size work van with no rear windows in the city every day no problem but for some reason driving these cars bothers me. Especially when backing up & passing.motoguy128 wrote:Just adjust your sideview mirrors correctly. Your rearview mirro is a convenince, but should not be relied upon. Motorcycles and most commercial vechicels don't have them.
It would be nice if that was the case, but unfortunately, some cars just aren't designed in a way that promotes good visibility. Here's an example of what I see when I look over my shoulders to check blindspots ('04 Maxima--my father's, not mine--but a good example of my point here):Althalus wrote:IMO there is no such thing as a blind spot, if you drive correctly, and look over your shoulder like you're supposed to when turning, you should never have a problem.
By the way, welcome!100 Watt Walrus wrote:New here. Hi all.
The only trouble I've had with the rear pillars has been backing out of diagonal street parking spots. Those pillars are EXACTLY where oncoming cars would be seen. I i-n-c-h out of those spots.
Otherwise, between 1) aligning my mirrors so no car leaves the view of one mirror without passing into the view of another or into my own peripheral vision, and 2) always double-checking over my shoulders, I've found these pillars to be no problem.
