darylzero wrote: ↑Fri Jan 17, 2025 4:21 pm
Was there a giant piece of salt stuck in the tone ring or something?
That's entirely possible. Not the tone ring, but if the sensor insulation is compromised then salty water will definitely screw it up and clean water will probably unscrew it. In fact, spraying a 5% salt solution and looking for signal changes with a scope is a pretty common way to test electrical circuits for intrusion. Most people think water is electrically conductive, but that's a myth. Distilled water has a resistance around 180K ohms per meter, for practical purposes it's an insulator. It's the impurities which render it conductive. Drinking water is 2~200 ohms/m, depending largely on the chlorine and mineral content. Seawater is generally 0.2 ohms/m, which is about 4 times more conductive than a typical spark coil primary. In a salt state, that's pretty much what was underneath your car.
