abnrjd »
https://forums.nicoclub.com/abnrjd-u185922.html
Fri Jun 28, 2013 8:43 am
I have replaced the rear output shaft seal on my 04 Nissan pathfinder THREE TIMES!!!! and it still leaks. The indicator is that the rear glass gets covered with the oil from the transfer case. I would truly appreciate it if someone knows the cause, remedy of WTF is going on with this truck. I have no problem with the transfer case, transmission, or anything. I will say that when I am in the process of removing the seal, oil pours from the rear of the transfer case when I remove the old seal. please help!!!!!
