Rear oil seal install question ...
Jesse SR20
Car: 1990 S13 fastback
Installed a new rear seal on my SR today. When I tapped it in, I first used a block and tapped the seal flush with the housing.
But then I thought it might need to go in further, so I used the old seal upside down to tap it in and I made sure the inside of the seal bottomed out. So the seal now sits recessed below the edge of the housing.
Is this correct ? I figured this is the correct way to do it.
robbbby
I accidentally did the same thing on mine, tapped it in a little to far. I'm pretty sure it should sit flush since thats how my old one was before I took it out. I highly doubt that it will leak though just because it was pushed in more. I was a bit worried at first to.
9240sx
Car: What i believe to be the cleanest s13 in the world.
SR20DET + RS*R-Apexi-Nismo-Trust-HKS= 100% pure love
Yes,Thats the right way to have it.
mynismo
you're fine. the seal you bought is a revised version of the original seal. it will sit in further than the stock one.
Jesse SR20
Awsome.
Thanks guys.
tiger
Hey I am needing to order a new front and rear oil seal to rebuild my SR... should I get this from a 91 SE-R Sr20De RWD?
180fan
Car: 89 fastback
check the parts guide. I had the part number listed there as well.
