Rear mount turbo Q videos...
Brew Q
Car: '92 Q45 91k miles, '05 FX35
past: '99 740i (r.i.p.), '92 Maxima SE, '89 Maxima SE, '04 FX35
the Beast is alive and well. I had to fix a couple minor things, but she's running STRONG now. :chuckle: currently tops out around 7.5 psi. I could push it more, but the transmission doesn't want to!
Enjoy!
http://vid22.photobucket.com/albums/b32 ... 173912.mp4
http://vid22.photobucket.com/albums/b32 ... 164735.mp4
http://vid22.photobucket.com/albums/b32 ... 170051.mp4
http://vid22.photobucket.com/albums/b32 ... 182026.mp4
http://vid22.photobucket.com/albums/b32 ... 182129.mp4
if I can figure out how to post vids directly instead of links I'll edit this...
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Auxiliary ATF cooler required, at the least.
Give me a call next time you are in Austin as I happen to have one B&M that will work great.
Surprised you didn't go the way Sijoko did his.
Brew Q
maxnix wrote:Auxiliary ATF cooler required, at the least.
I'm actually running an ATF cooler, plus an added oil cooler for the motor, plus a cooler on the rear for the turbo oil (separate system)
Sijoko built this one. :biggrin: It is a LOT easier (and less hours) to rear mount than do what he did on his... mine might even spool a tad quicker - he'll tell you that as well. Only difference right now between his car and mine is with his high stall TC, he's in boost from a standstill.
Q451990
:biggrin: :biggrin: :biggrin: :biggrin: :biggrin: :biggrin: :biggrin:
sijoko
Car: Black 1994 Infiniti Q45 Turbo, Pearl White 2014 Maxima Sport
Man, that thing sounds like a jet ready to take off....Bret's car is a monster with all the new found power. All he needs now is a high performance trans and some big brakes....maybe some stealth paint too :bigthumb:
94Q45Beast
Car: 1994 INFINITI Q45t w/HICAS
1992 INFINITI Q45
2017 INFINITI Q70S AWD BLACK ON BLACK
I can hook him up with some big high performance 6 piston 2 piece rotors brake kit for the front and rear with whatever design rotors that come to his mind, wavy, drilled, slotted, or all 3.... website is in progress. coding everything (HTML 5, Java, CSS, PHP, XML...ect.) from scratch is a B@%#$ so I'll take any orders for the brakes in pm with any additional information needed, hoses are undergoing testing right now.
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
01 B15 Sentra (Daughter's)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
Hard for me to tell from the videos, that is your a/f ratio displayed (large font), and the vac/boost in smaller font?
I love the video with the 3-4 shift at about 110. I've always wanted to make the 3-4 at redline, but still havent found a clear enuf stretch of open highway in daylight (too old to drive that fast at night....). Best i ripped that shift at 115.
nice sound!
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Nice... What's up with that road noise, you can't hear the engine....!!
You need a MT in that beast... Looks wicked cool though, congrats!
Brew Q
elwesso wrote:Nice... What's up with that road noise, you can't hear the engine....!!
Some of the roads around here have been resurfaced, and when they do its like gravel sticking out of asphalt... Loud.
Just got a Go Pro today as a present! So I'll try and get some better vids and on smoother roads. I'll get one at idle and backing out of the driveway, definitely sounds great.
She'll definitely need a beefy trans rebuild soon! :gapteeth:
and Yes the big number is AFR and the small is boost. I'll flip it in the next vid, so big is boost. The 4 down to 3 shift was uninentional, I usually put it in 3 on the highway for a pull, but forgot I was in D :crazy:
The beast just turned 100k miles the other day - wish I had a pic of it!
