if the reasoning for it to not work is that the car was designed so precise for air flow that air would not flow though it... then Im afraid that is not correct.
The car was not made to be turbocharged, the car was not made to be turned into an AWD version, the car was not supposed to have its weight reduced to under 1300kg, the car was not designed to take in an sr20det. Who ever did that did not think, hey nissan didnt design it for this.
Eitherway, keep in mind that there is a HUGE difference in cost effectiveness of mass manufacturing car design and backyard project car design.
I was ignoring the weight of the fuel cell itself and was estimating the mass of the fuel in the fuel cell.
I do think it will work though. Cuz high flow rad fans alone should flow enough air through them.
I was thinking if it could be made in a rectangular tube, with the rad in the middle and the fans sealed to the end of the end of the tube, it should flow well...
yes, there is the exhaust in the way. There are also the suspension bits, differential restricting the flow.
On the budget, for the exhaust all I am planning to do is ceramic wrap it. Maybe a heat shield on top.
The differential and suspension bits I cant do much about. What I could do is mount a 12" height rad at like say a 40 degree angle, further back to the end of the diffuser than near the spare tire bucket...to promote flow...
but yea, I am slowly researching aluminum radiators now. There are a lot that could work but I have not found the ideal one yet. I am also looking at the option of having a water based intercooler using the same rad.
The rear side window vents I thought about... but that would have been nice for a gigantic air intake box in the trunk that could feed it to the turbo in the trunk...but yea, I guess it produces too much heat to be in the car.
but yea, if anyone one knows a radiator that is less than 12" in height it would be useful to know.
Most of the ones in small height that I found are made for engines smaller than 3.5l. If I dont find one, I might have to use 2 small radiators side to side, the problem would be the stress on the water pump.
I could go oversize and use the same rad with a second pump for a water based intercooler...the issue again is height...
I took some rough measurements with the car on the hoist, I didnt take the muffer off so i might not be accurate but a lot more needs to be cut out of the chassis for a short normal radiator.
Im surprised at how cheap radiators are....compared to say a plastic plenum spacer...the aluminum rad is cheaper with the rad fans included. The spacer is a joke in the way its priced. You would realize if you had an idea of manufacturing cost, but then the Z33 parts market in North America seems small and the consumers do seem to judge the quality of a product by the price most of the time.
