EXceptional »
https://forums.nicoclub.com/exceptional-u94093.html
Tue Jul 17, 2012 5:38 am
Welcome to the Forum. We're glad your here.
Somebody is playing around with the Mirror Control Knob. You need to set it and leave it alone. If there's two drivers for the Car, utilize the #1 and #2 Driver Buttons to adjust the Mirrors.
In your 2012 EX35 Manual, look up Page 3-24 which is in the "Pre-driving checks and adjustments" Chapter.
...a copy and paste from the Owners Manual.
Reverse tilt-down feature (if so equipped)
When backing up the vehicle, the right or left outside mirror will turn downward automatically to provide better rear visibility.
1. Push the ignition switch to the ON position.
2. Move the selector lever to the R (Reverse) position.
3. Choose the right or left outside mirror by operating the outside mirror control switch.
4. The selected outside mirror surface moves downward.
When one of the following conditions has occurred, the selected outside mirror surface will return to its original position.
. The Gear selector lever is moved to any position other than R (Reverse).
. The outside mirror control switch is set to the center position.
. The ignition switch is pushed to the OFF position.
