Rear Marker Replacement - Absolutely STUMPED!!!
94J30tPAD
Car: 94 J30t, 88 Wagoneer LTD
I just bought a 94 J30t that had almost every light on the outside out!Got the taillights replaced, and after a few minutes, got the front side markers replaced by going from underneath the front panels. But the big problems are that I can't figure out to replace the rear marker bulbs. Looked inside the truck, and there is no opening or the marker. Looked underneath, and there are no removable panels. Saw one at the wreckers, and you don't have to remove the bumper do you just to change a buld do you?
Gerardjg
Car: 2007 Cobalt LS
2011 Hyundai Accent
2016 Kia Optima
The front and rear side markers just pop out. Use some padding around a flat screw driver to protect the paint insert it between aft end of the marker lens and the body push the lens fwd and outward.
Check your Email
