SmithSR »
https://forums.nicoclub.com/smithsr-u5241.html
Sat May 24, 2003 6:20 pm
are you fairly certain the oil pan is leaking?? reseal the pan then check for leaks. If no more leaks are evident, then problem solved!! I'd say do one repair at a time if you're troubleshooting, sort of trial & error, unless there are other *obvious* problems.
