rear main replacement
robtheasian
Car: guitars music, and driving fast
I was wondering how hard it is to replace the rear main on the 240 when the clutch is being replaced at the same time. do I have to remove the engine from the motor mounts and pull the oil pan off? I keep getting different answers. thanks. rob.
NISTECH
no ...pull the flywheel off and it is right there.
robtheasian
sweet!! that's what I wanted to hear!!! thanks.
Scott McLellan
If you pull the flywheel be ready to replace those bolts that hold the flywheel on though. They aren't the reusable type. When I was torquing one down after putting on the flywheel one broke in half at like 25 ft/lb! That kinda got me scared. I ordered new ones from the Nissan dealer, something like $46 with shipping.
GroundZero
mine went back on fine, are you sure they didn't snap at 125 lb/ft?
Scott McLellan
Yeah, I'm sure. In the book it says to replace them if they have been retorqued more than twice or if they are more than two years old. Something like that. I just thought maybe I could get away with it like you Ground Zero. When I called the Nissan dealer he said he has had people order the exact same bolts that I did so I'm not the only one. Trust me though, it's not fun having to worry about how you are going to remove a piece of a bolt from your crankshaft. Take your chances if you want though. You might get away with it, you might not.
GroundZero
ehh.. i'll have to remember to get those arp replacements next time i have the transmission out.
