Thanks for the input, I decided to get it fixed. Hopefully get the car into the shop in a week or two.Ziggy1621 wrote: For the leak, definitely get it fixed. To start looking at where the leak is, what kind of oil is it? transmission fluid is gear oil, so thick and super smelly, engine oil should be lighter. Is it coming from up top (check with a flashlight). If it is the rear main, it is not too difficult to change yourself
That looks relatively easy to fix, I think I'll try that before I go into the shop, maybe this will fix the issue. It's not a super big deal, but it makes getting out of the driveway somewhat of a hassle in the morning for sure.Ziggy1621 wrote: For the other issues:
1. You can adjust your idle on the IACV: http://www.nicoclub.com/archives/adjust ... level.html
- Being an old car never stops something from being fixedMy car is a 90 and runs like a new car! I would check the coolant temp sensor. If it is failing, it would cause it to run weird and idle weird at cold. You can check the ECU's codes as it will sometimes throw a code for the CTS. http://www.nicoclub.com/FSM/300zx/
While the ride quality is not horrible, it's certainly not perfect. It can be pretty 'bumpy', but the roads are also pretty miserable here, so that could account for it too.Ziggy1621 wrote: 2. Sounds like you may have a bad U joint in your driveshaft. Is there any vibration while driving?
Thanks, I'd like to get this fixed, it would be nice to have a little smoother ride.Ziggy1621 wrote: 3. Probably the top mounts of the struts, when the rubber gets old and starts giving way, it can lead to metal/metal contact that produces a squeak. The other possibility that I've heard about is the hood hinge.
