swimshark »
https://forums.nicoclub.com/swimshark-u57894.html
Sat Dec 19, 2009 7:28 pm
Today I put the 240sx s13 coilovers on my J. There was only one issue with the install which was luckily easy to overcome. The bolts on the top hat for the s13 are narrower than the one on the J30. To overcome this I took the top hats off of the stock struts and put them onto the coilovers. I included some pics of what I did with the top hats and some pictures of it installed on the car. I will put some more pics soone on how it sits.
As for the TT sway bar. It was a little tricky to install because I thought at first I would have to remove the back half of the exhaust, but I was able to work it onto the car with only disconnecting the exhaust hangers. I can notice a big difference in handling. So far I have custom made solid tension rod bushings, 300lb/in lowering springs in the front, 240sx s13 coilovers and TT sway bar. There is pretty much no body roll at all.
