Rear Lower control arms
psouth
Car: 2001 Pathfinder LE
I have the classic rear-end wobble due to worn out bushings on the rear lower control arms. I bought new control arms and bolts. I have tried without success to break the nuts with an impact drill. My only hope now is to cut them off. I can't use a torch on the driver side due to the gas tank. Does anybody have any suggestions on the best way to cut these off?
Thanks!
Paul
02pathy
try a 3/4" breaker bar or in other terms a 4' or 1m in america piece of iron pipe over a 1/2" ratchet, lube it up the night before and b4 u lube it up u might want to sand it down with a wire brush
AlabamaDan
Car: 2015 Infiniti Q70
1998 Infiniti QX4
Try some Power Blaster, let it soak then the pipe over the ratchet. You'll either break it loose or twist if off.
nissandoms47
Car: 2002 Nissan Pathfinder SEV6-Custom 7" lift-33-1250R15 BFG KM2- a bunch of other s*** i cant think of
Just a cutoff wheel. The axle side bolts of the control arms will definatly be rustwelded to the bushing sleve. you'll just have to cut them off and replace the bolts. but it looks like you got new bolts already. Cut between the axle bracket and the control arm on each side.
