Rear light dont light up, break does HELP
Alfredbro
Car: 200sx rps13 Sr20det s15 stock turbo n injector
Hello im new... Im desperate hw to fix this.. Well usually i manage to get help from this forum, but now.. Idk..
I checked my fuse near kick, its working. Just 1 didnt work.. Right side below. 2nd from right one. I use new fuse. But nothing happen. I turn on mid light. Rear lamp not working but break is working. I check all bulb is working. I use test light n multimeter to check rear f there got power. Nothing.. No power... I really need help with this. F there is possible diagram, picture where to check... Now i cant drive night time... Boring... I need help.. Thanks in advance.. Here is my place charge BND150 (us$115 just to check the wire.. Rewiring blabla.. :crazy:
Hijacker
Car: '92 240sx Convertible
'94 F-150
www.nicoclub.com/FSM/240SX
Get a service manual from there and go to the EL section. It has all the wiring diagrams on the tail lights.
What you're describing sounds like a broken wire somewhere in the system. Check the wiring harness going to the tail lights for wires rubbed bare. I had my harness rub on my scissor jack and rub through the sheathing of the stop lamps and it was doing something similar to what you have described
Alfredbro
Thanks man, ill check and update
Alfredbro
Link died :(
Hijacker
'94 F-150
http://www.nicoclub.com/FSM/240sx/91-94/
Sorry, it's case sensitive.
Sideways570
If you're talking about your back up lights not working there is a plug one the trans not too sure which one it is but it's sort of in the middle of the trans. I would check the wires on that connector and make sure they aren't broken.
