The fuse is the rear lamp fuse under the hood in the engine bay and the lights I am talking about are the gauge cluster, clock, and anything that is normally on when the headlights are turned on. I am 100% positive the rear lamp short will fix that problem though.Q45tech wrote:So everything was fine until you redesigned the electrical system.
You will need to follow the wiring diagrams and find the short you most likely created,
Leave the bulb check module disconnected until you find the inside short.
Exactly which fuse and which interior lights? Do side lights for and aft work?
Have you replaced any of the small illumination bulbs in the remote window switches, back of clock, heater, speedo, etc. recently? I ask because I burned a fuse replacing one of these bulbs with a screwdriver with the lights on and when this hapenned the headlamps were stuck on high beam, there were no tail or running lights (I had brake lights), and all the small interior bulbs went out. Good luck finding your gremlin.lasoyafan wrote:.....and searched the diagrams for a short and have found nothing. I am really confused as to what is going on or how to fix it. Any help?
so basically I'm better off having someone else do it?Q45tech wrote:Sometimes a divide and conquer strategy works,
Using in line plastic fuse holders with pigtails divide the 2,3,4 circuits up, besure to calculate the draw on each of 2,3,4 circuits to downsize each fuse.
In my case it was just a matter of replacing the 10 amp tail lamp fuse. As you know the correct contact point is hard to find so it helps to have the lights on when reinstalling the microbulb assemblies. I now use a plastic screwdriver made out of a cheese and cracker paddle (shown in pic).lasoyafan wrote:Yes that is exactly what happened how did you fix it?
The diagrams won't show you the short....lasoyafan wrote:..... searched the diagrams for a short and have found nothing....
I had the wire that sent data to the gauge cluster snipped so it wouldn't read the lights were out, but I put it back.qsiguy wrote:How did you try and "bypass" the sensor? Are there some jumper wires or something you installed there touching themselves or ground?
Are you loosing brake lights, runing lights, reverse lights, third brake light, or what specifically. "Rear Lamps" is pretty vague.
What amperage is the fuse you are replacing?
