Rear Hub Diameter Needed. Help!!
tirpitz56
Car: 2001 impreza
I'm doing a R200 swap into my Impreza and was wondering if someone had a hub laying around that they could measure. I need the diameter of the neck that goes into the bearing assembly.This is the STi hub on the right.http://ek9.djii.com/09062008043.jpgThis is the 240 4 to 5 lug conversion.(4 or 5 should be the same diameter)http://www.frsport.com/images/...5.jpg
I know Subaru and Nissan us a alot of the same stuff but the Nissan stuff is more heavy duty. I can get my hubs machined but just wanted to check to see if the Nissan hub will press into my bearings. Plus I already have the 240sx axles so it could just be plug and play.
Thanks to anyone that can help.
