bmlawless »
https://forums.nicoclub.com/bmlawless-u85265.html
Tue Mar 18, 2008 11:51 am
I doubt that the couch hauling did it. I don't know the furniture transport history of my vehicle, but since you and Ihave it and I think KoukiS14 had it too, it is probably a defect. Here is a pic of mine before I did anything. It basically was not contacting the hinge tongue on the opposite side at all.
After working on it, it is touching the other side, but it is only a hair into the hole. Since it appears to be working its way out again, I will probably remove the hinge from the vehicle and hammer the pin in against a hard surface like an anvil. Once those "fins" are set into the aluminum hinge, I can't see them slipping out. My guess is that they weren't properly seated from the factory.
I should mention that this is only on the driver's side. The passenger side pin is in there nice and snug ans not going anywhere.
