autotech43 »
https://forums.nicoclub.com/autotech43-u4010.html
Mon Jan 12, 2004 1:18 am
Omaha, we have replaced OR repaired a few of the rear hatches on the FX vehicles. What we do is perform a pull test in several area of the rear hatch, if the hatch fails the pull test at the bottom area of the hatch, it gets replaced. At the top area as you were stating, if the trim piece is deformed, the hatch gets replaced, if the trim is not deformed, Infiniti has sent us a repair kit to repair the FX vehicles. Either way, the fix isn't that difficult to perform. We have repaired AND replaced several. What is actually going on is where they glued the outer skin of the hatch to the inner support, some of the vehicles, the glue has came loose resulting in the trim to deform. In reality as many of the FX vehicles that we have sold, the actual repair or replacing of the rear hatch has been very minimal. Have it checked at your dealer, if things are fine now, you most likely won't have any trouble with that concern later on down the road.
