elmitchell57 »
https://forums.nicoclub.com/elmitchell57-u304091.html
Thu Nov 18, 2021 4:10 pm
I have a 2016 Nissan Rogue SL. At 64000km, (warranty ended at 60000), the rear hatch went up as normal when activated, and I stepped under it, only to be hit on the back of the head by the hatch coming back down, fast. So that happens every time now, hatch goes all the way up, and immediately comes down fast to the halfway point. I have tried a reset, no resolution. I took the vehicle to the dealership, and they say it is both shocks, and the estimate for repair was $2000. I told them to forget it. To me, it appears to be an electronics control fault, and not both shocks failing at the same time. If I push it back up manually and let it go, it forcefully comes back down to the halfway point. A couple of times I have reset (by holding the close switch for 10 seconds) while holding it at full open, and it still comes down hard, but when the close switch was pushed, instead of closing, it went full open and back down to halfway point, and I had to close it manually. Next time opening, it is back to original fault. So how can the shocks themselves be faulty? How do I go about checking the control system, where is it, etc. Anyone with any ideas, any help is appreciated.
