HoosierMurano »
https://forums.nicoclub.com/hoosiermurano-u146206.html
Wed Oct 28, 2009 1:46 pm
Thanks for the help! Your advice helped me fix it on my own.
I had already popped off the small panel on the inside of the hatch to get to the locking mechanism and it looked like the latch was traveling the full range. Knowing that a little more force might be the trick, I used a 1.5 ft x 3 ft piece of ½” plywood as a lever. I could get the hatch to lift just enough to get the plywood in, then while hitting the release pushed down on the plywood so the bumper acted as the pivot point and the plywood pushed up on the hatch. The 3 ft. edge of the plywood was under the hatch to avoid putting too much force on a small area and bending the hatch. It popped open after just a couple of tries.
