Philsnotfalling »
https://forums.nicoclub.com/philsnotfalling-u10849.html
Tue Dec 30, 2003 4:35 pm
oh rust.... you should have someone that knows paint and body work on your car. Rust is a cars cancer. I did restorations for awhile and rust can be delt with in several ways, case sensitive. if you have rust on just the outside sanding it off and re-sealing the metal is all that is required. Looking at my s13 with spoiler and rust, I would say that its rusting from the inside out. I haven't cared too much about the body work end of it since I see enough everyday at work and I'm trying to get the car running first. But basic rule, if you can't see it you can't fix it. The rust may have spread to certain parts of the inside of the hatch to where you cannot see. You can try to get as much as you can but if not all is taken care of it will rust again, if other rust exsists. You can use a rust to primer "paint", which I found some at walmart (not sure of the quality). Treat this stuff as bare metal though, still etching it and primering on top of it, so on and so forth. If rust holes have developed.... going completely through the metal, makes sure both sides of the metal around the hole are completely clean. Depending on the size a small patch panel can be made out of sheet metal you buy at hardware stores. Weld through primer all areas front and back of all metal. Secure in place and slowly weld the area. Experience is highly recommended you can seriously warp the ell out the panel by getting it too hot. Good method is tacking it once at a time and cooling it with water and a rag or sponge untill all the area is welded. Grind the welds down till the area is flush, again not getting it too hot... will warp. Use alittle filler to smooth the area out and prime and bla bla bla. The inside of your welding can be covered with self-etching primer then some undercoating.
Or another option which I have never used but a friend thinks its soooo great, is Por 15 or something. Its a system that inhibits and converts all rust it come in contact with. Don't know much about it and don't care to. To me it sounds like just a quick fix, expensive quick fix.
Rust is some nasty stuff. Bomexs13 your rust will come back in the forms of bubbles and could possibly spread underneath the paint. My suggestion, talk sheet about the paint shop no matter how cheap they were. And then strip where you know there is rust and repaint your ride.
eddiec try to find a hatch with no spoiler (the ones with no spoiler seem to fair better than the ones with) and trash the one you have if there are that many holes. If you wanna put the spoiler back on drill your mounting locations and then have a paint shop etching pimer the holes drilled first then have them paint it.
Rust is like cancer it will keep spreading and spreading. If you can't see the whole area then you can't fix it all.
