The entire spoiler is scratched up pretty bad, and part of the brake light has some garage paint on it. Around the brake lights, the left side has a good dent on it. I am going to DIY it, as sand paper is cheap and spray paint is also cheap.DTASFAB wrote: ↑Mon Apr 16, 2018 2:41 pmIs the glass scratched or is it just paintwork and a light fixture? Did you scrape the majority of the finish on the hatch under the glass? Is it dented too or just scratched? If the paintwork is done, could you live with the light fixture the way it is? They're not too expensive and easy to replace, but I think if it's just scraped and not cracked, it's not a significant eye sore, because it won't jump out to the eye for most people.
ImStricken06 wrote: ↑Tue Oct 07, 2014 8:32 amTHIS IS A WARNING TO ALL NEW AND SEASONED USERS:
2. USE THE CORRECT TITLE: That means, make sure your title has the topic at hand. Don't title something: "I have a question" or "Small concern" or "strange issues". Instead title it: "tire tpms question" or "Rear bumper paint issue". And don't title it one problem, and list 10 different issues that are completely unrelated! example: "Strange noise when driving" and then you go on about asking questions about oil changes, led headlights, new rims, and your mothers' ford bronco transmission issues, etc.
-ImStricken
Thanks man! I clearly didn't knew how I should word this thread, as it was an unexpected accident.Rogue One wrote: ↑Mon Apr 16, 2018 5:55 pmTitle revised.
-ImStricken![]()
