Rear Gear Ratio...
89 240 SOHC
Car: 1990 Micra S13....Micra with S13 Seats and other S13 accents to follow
anyone know what rear gear ratio a 1989 240sx 5-speed came with, also an automatic?
virus77
Car: 95 S14, 71 240z, 97 e320
4.08 auto and manual are the same AFAIK
89 240 SOHC
Thanks.....trans ratios for the 5-speed?? just wanna know how screwed I am for top speed...
masticatingcow
Car: 94 Mazda FD3S
I'm not sure what the exact ratios are, but you can expect your 5-speed to gear out at 161-163mph, assuming your final drive is stock. That's not rev limited or speed governed. At 3000 RPM in 5th gear, S-chassis cars are usually going 70mph, plus or minus one. Given that:
In 5th gear,
3000 RPM / 70mph = 6900 RPM / X,
your speed at redline in 5th will be about 161.
Stock transmission, stock final drive gear. Hope this helps.
EDIT: You can probably push it just a little harder, and if you can get an engine that revs higher, you're golden. Mate a KA transmission to a tuned CA, which has been known to rev up to 8000, and your top speed suddenly equals 186mph. Heh heh... good luck getting there, though.
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
240SX 5-speed is the "FS5W71C"...
Gear ratios are:
1st........2nd......3rd........4th........5th3.321...1.902...1.308.....1.000....0.838
Rear end is 4.083:1, as mentioned.
- Brian
