eaglecat769 »
https://forums.nicoclub.com/eaglecat769-u235982.html
Thu May 14, 2015 11:14 am
Bump.
Thanks for the images. I appreciate the banter, as I have taken things apart for S-n-G more than once.
Seriously though... why did you expose the floor? Did you happen to do so in order to apply sound damping material such as Dynamat or Raam's BXT II to the floor? If so, did that happen to help with road noise? I see in your photos that Nissan put a healthy coat of their stamped-on tar/fiber damping stuff under the front occupants' feet, but left barren the area under the front seats and and under rear occupant foot area. In the photos the rear 2/3's of the floor trays look like cookie sheets ready for a pot-banging-toddler-tantrum. So it seems plausible that application of damping material could significantly reduce low frequencies (the worst road noise right now is low frequency rumble) that would be able to pass thru that thick foam pad (which should kill most mid-to-high frequencies).
If you didn't apply damping material to the floor, do you know anyone who has? I will proceed and post my results either way, but applying Dynamat Extreme to the floor is going to be my weekend project. I intend to start with the "rear occupant calf plate", and the rim right above it, since it seems to ring pretty good and has just a little denim batting between the carpet and the metal. So far I have meticulously done the doors and most of the rear hatch, but have not yet achieved the desired reduction in road noise, but I anticipate the Bose will sound amazing from the work to-date once all is reassembled.
The roads here (northern WA state) are much louder (due to studded tires used by others, and general composition) than I am used to, resulting in sound levels in excess of 80 dB for the Rogue on the highway.
Thanks!
