breadbox »
https://forums.nicoclub.com/breadbox-u49113.html
Wed Mar 10, 2010 6:53 am
If you post pictures of what you are attempting to fix, some one could give you better more specific to your cause advice.
If it has mean dents, try inflating different size basketballs and football inside the car to push it out. Some one on here did it with a car jack and it worked okay.
Rust is one of those get rid of it things. POR15 might be in your future. Wire wheel to get off the surface rust. You may need to cut some sheetmetal out and replace it, depending on the severity.
