Rear ended, trunk wont open
nickbrown92
Car: 2007 Nissan Sentra 2.0S
Rear ended a few months ago, took the car to my dad's collision shop and now the trunk won't open from the outside. I have the keyless entry system, and the remote and trunk release button on the trunk lid itself won't release to open up. What do i need to repair/replace?
frapjap
'07 Subaru Legacy
You need a precision adjustment lever.
or stop being lazy, crawl your butt in the trunk with a light, pull apart interior panels and manually pull on the trunk cable.
Bubba1
Car: 2003 Nissan 350z
2024 Honda HR-V
2008 Toyota Corolla S
2001 Toyota Avalon XLS
frapjap wrote:You need a precision adjustment lever.
:chuckle:
Did you ask your father's collision shop the same question? :confused: Unless you need a new battery in your remote, the collision shop might need to do a little more straightening, so when the release is activated, (assuming it wasn't damaged in the accident and is functioning), that it clears the grip.
frapjap
'07 Subaru Legacy
Whoops, I misread. My apologies. I didn't see that the car was already repaired. But the crowbar still stands.
Encryptshun
Car: 2005 Nissan Xterra
Did you check to see if the pigtail between the main trunk loom and the trunk release was intact and/or plugged in correctly?
300ZXttZMAN
:welcome: to Nico!
Will the trunk open from inside the car?? If so that would more than likely mean the battery in the remote could be dead.
nickbrown92
the remote works fine to lock/unlock the car. let me talk to my old man and ill see what they come up with
