I didnt have enough time to break and I ended up rear ending some cadi!
this is what I ended up with
How should I go about fixing this? sanding it and stuff..?
what do you mean by you dont have a c-mod?devilmagic wrote:ouch .u dont have a c-mod . but looks like it can be repaired . but lots time will be invested.
thats what i was gonna do. what grit(s) should i use?infiniti_lineup wrote:Sand down the damaged areas, apply bondo, re-sand the areas, and then re-paint. Use high grit sand paper and automotive bondo - both of which you can get from Home Depot.
Good luck and let me know if you need any more information!
