Car specs;
-S-chassis 248k miles
-No suspension work expect for some Megan Coilovers
Here is a pic of my freshly swapped engine
Sorry everyone I was on Vaca and i neglected to get online lol. . FYI..car had been recently aligned with 4 brand new tiresmechanicalmoron wrote:Is it in every gear?
Maybe check that motor, transmission, and differential mounts are all tight.
And maybe make sure that your driveshaft carrier bearing/u-joint/balance is okay.
You can eleminate the actual rear end (or the front, depending on the result) by checking neutral. If it happens when you race the engine in neutral when you're parked, then it's in the motor/transmission or their mounts, and if it only happens when you're driving and in gear, then it's between the rear of the transmission and the wheels.
I guess it could POSSIBLY be a bearing or something in the transmission and break my example, but it would be less likely I think.
