Sil40sK wrote:I thought the R230 was what comes in the Z33 chassis? And the Z32 TT still used an R200. I don't know though, I'm pretty dumb, haha.
300ZX TT uses the 3.69 R230 (90-93 Q45 uses the same hubs and similar axles, which are 32 spline. The axles have slightly different lengths compared to the TTZ to make up for the size differences between the R200 and R230). The early Q45 R200 has 30 spline stub axles, which I know for sure are larger than the 300ZX NA's. I'm not sure of other stub axle spline counts but I'm sure the R230's are equal to or larger than that.
300ZX NA uses a 4.08 R200.
I can't remember for sure, but I believe the 350Z uses an R200 with the option of a 3.36 or a 3.545 ratio.
The Armada has an R230 with 2.946 and 3.357 ratios with stub axles that are a good deal larger than the Z32 TT's. The R230's are slightly large than a Ford 9" differential...
